[postgis-tickets] r15375 - Make copy of string that will be deallocated and make bool type clear
bjorn at wololo.org bjorn at wololo.org
Fri Apr 28 09:10:22 PDT 2017
Author: bjornharrtell
Date: 2017-04-28 09:10:21 -0700 (Fri, 28 Apr 2017)
New Revision: 15375
   trunk/postgis/mvt.c
Modified: trunk/postgis/mvt.c
--- trunk/postgis/mvt.c	2017-04-26 20:43:28 UTC (rev 15374)
+++ trunk/postgis/mvt.c	2017-04-28 16:10:21 UTC (rev 15375)
@@ -73,7 +73,7 @@
 struct mvt_kv_bool_value {
-	bool bool_value;
+	protobuf_c_boolean bool_value;
 	uint32_t id;
 	UT_hash_handle hh;
@@ -274,7 +274,9 @@
 	uint32_t i, k = 0;
 	bool geom_name_found = false;
 	for (i = 0; i < natts; i++) {
-		char *key = tupdesc->attrs[i]->attname.data;
+		char *tkey = tupdesc->attrs[i]->attname.data;
+		char *key = palloc(sizeof(*tkey));
+		strcpy(key, tkey);
 		if (strcmp(key, ctx->geom_name) == 0) {
 			ctx->geom_index = i;
 			geom_name_found = 1;
@@ -428,9 +430,9 @@
 		Oid typoid = getBaseType(tupdesc->attrs[i]->atttypid);
 		switch (typoid) {
 		case BOOLOID:
-			MVT_PARSE_DATUM(bool, mvt_kv_bool_value,
+			MVT_PARSE_DATUM(protobuf_c_boolean, mvt_kv_bool_value,
 				bool_values_hash, bool_value,
-				DatumGetBool, sizeof(bool));
+				DatumGetBool, sizeof(protobuf_c_boolean));
 			break;
 		case INT2OID:
 			MVT_PARSE_INT_DATUM(int16_t, DatumGetInt16);
