[postgis-tickets] [PostGIS] #3740: ST_AsMVTGeom can produce invalid output if clip_geom is true
PostGIS trac at osgeo.org
Fri Apr 28 14:07:51 PDT 2017
  Reporter:  Björn Harrtell  |      Owner:  Björn Harrtell
      Type:  defect          |     Status:  closed
  Priority:  critical        |  Milestone:  PostGIS 2.4.0
 Component:  postgis         |    Version:  trunk
Resolution:  fixed           |   Keywords:
Changes (by Björn Harrtell):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"15378" 15378]:
 #!CommitTicketReference repository="" revision="15378"
 Rework ST_AsMVTGeom clipping logic
 Closes #3740
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3740#comment:1>
