[postgis-tickets] [PostGIS] #3682: Strange fieldlength in result of pgsql2shp
PostGIS trac at osgeo.org
Sun Apr 30 19:43:52 PDT 2017
  Reporter:  postgispaul    |      Owner:  robe
      Type:  defect         |     Status:  closed
  Priority:  medium         |  Milestone:  PostGIS 2.4.0
 Component:  loader/dumper  |    Version:  2.0.x
Resolution:  fixed          |   Keywords:
Comment (by robe):
 postgispaul,
 Can you try this out and see if it fixes your issue. I unfortunately don't
 have ArcGIS to test with.  If it does and pramsey and strk have no issue
 with backporting, I can backport to 2.3 as well.
 If you need windows binaries - you can get them from here in about an
 hour.
 http://winnie.postgis.net/download/windows/pg96/buildbot/
 I'm still troubleshooting the 32-bit runs, so the 32-bits are too old to
 test with.  I assume you are runnning 64-bit so probably a non-issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3682#comment:4>
