[postgis-tickets] [PostGIS] #3801: postgis dump restore test is broken
trac at osgeo.org
Sat Aug 5 09:16:38 PDT 2017
Reporter: robe | Owner: robe
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.4.0
Component: build/upgrade/install | Version: 2.3.x
Resolution: | Keywords:
Description changed by robe:
Old description:
> So I was trying to troubleshoot why travis is failing on upgrade test,
> and I get a failure as well (at least when testing against postgresql 10
> beta2
> pg_dump: too many command-line arguments (first is "-f")
> Try "pg_dump --help" for more information.
> At first glance it looks like args are out of order. database name
> should be the last thing in output. I'll try to fix.
New description:
So I was trying to troubleshoot why travis is failing on dump restore
test, and I get a failure as well (at least when testing against
postgresql 10 beta2.
At first glance it looks like args are out of order. database name should
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3801#comment:2>
