[postgis-tickets] r16143 - Add lwgeom_refresh_bbox to replace drop/add twostep
Paul Ramsey pramsey at cleverelephant.ca
Mon Dec 11 07:04:02 PST 2017
Author: pramsey
Date: 2017-12-11 07:04:01 -0800 (Mon, 11 Dec 2017)
New Revision: 16143
   trunk/liblwgeom/liblwgeom.h.in
   trunk/liblwgeom/lwgeom.c
   trunk/liblwgeom/lwline.c
   trunk/liblwgeom/lwlinearreferencing.c
   trunk/postgis/geography_inout.c
   trunk/postgis/lwgeom_functions_basic.c
   trunk/postgis/lwgeom_transform.c
Modified: trunk/liblwgeom/liblwgeom.h.in
--- trunk/liblwgeom/liblwgeom.h.in	2017-12-11 14:27:54 UTC (rev 16142)
+++ trunk/liblwgeom/liblwgeom.h.in	2017-12-11 15:04:01 UTC (rev 16143)
@@ -735,6 +735,10 @@
 extern void lwgeom_add_bbox(LWGEOM *lwgeom);
+* Drop current bbox and calculate a fresh one.
+extern void lwgeom_refresh_bbox(LWGEOM *lwgeom);
 * Compute a box for geom and all sub-geometries, if not already computed
 extern void lwgeom_add_bbox_deep(LWGEOM *lwgeom, GBOX *gbox);
Modified: trunk/liblwgeom/lwgeom.c
--- trunk/liblwgeom/lwgeom.c	2017-12-11 14:27:54 UTC (rev 16142)
+++ trunk/liblwgeom/lwgeom.c	2017-12-11 15:04:01 UTC (rev 16143)
@@ -688,6 +688,13 @@
 void
+lwgeom_refresh_bbox(LWGEOM *lwgeom)
+	lwgeom_drop_bbox(lwgeom);
+	lwgeom_add_bbox(lwgeom);
+void
 	if ( lwgeom_is_empty(lwgeom) ) return;
@@ -1556,8 +1563,7 @@
 	/* only refresh bbox if X or Y changed */
 	if ( in->bbox && (o1 < 2 || o2 < 2) )
-		lwgeom_drop_bbox(in);
-		lwgeom_add_bbox(in);
+		lwgeom_refresh_bbox(in);
Modified: trunk/liblwgeom/lwline.c
--- trunk/liblwgeom/lwline.c	2017-12-11 14:27:54 UTC (rev 16142)
+++ trunk/liblwgeom/lwline.c	2017-12-11 15:04:01 UTC (rev 16143)
@@ -344,8 +344,7 @@
 	/* Update the bounding box */
 	if ( line->bbox )
-		lwgeom_drop_bbox(lwline_as_lwgeom(line));
-		lwgeom_add_bbox(lwline_as_lwgeom(line));
+		lwgeom_refresh_bbox((LWGEOM*)line);
 	return LW_SUCCESS;
@@ -377,8 +376,7 @@
 	/* Update the box, if there is one to update */
 	if ( line->bbox )
-		lwgeom_drop_bbox((LWGEOM*)line);
-		lwgeom_add_bbox((LWGEOM*)line);
Modified: trunk/liblwgeom/lwlinearreferencing.c
--- trunk/liblwgeom/lwlinearreferencing.c	2017-12-11 14:27:54 UTC (rev 16142)
+++ trunk/liblwgeom/lwlinearreferencing.c	2017-12-11 15:04:01 UTC (rev 16143)
@@ -400,8 +400,7 @@
 	/* Set the bbox, if necessary */
 	if ( lwgeom_out->bbox )
-		lwgeom_drop_bbox((LWGEOM*)lwgeom_out);
-		lwgeom_add_bbox((LWGEOM*)lwgeom_out);
+		lwgeom_refresh_bbox((LWGEOM*)lwgeom_out);
 	return lwgeom_out;
@@ -457,8 +456,7 @@
 	return lwgeom_out;
@@ -528,8 +526,7 @@
 		if ( ! homogeneous )
@@ -762,8 +759,7 @@
 	if ( lwgeom_out->bbox && lwgeom_out->ngeoms > 0 )
 	return lwgeom_out;
Modified: trunk/postgis/geography_inout.c
--- trunk/postgis/geography_inout.c	2017-12-11 14:27:54 UTC (rev 16142)
+++ trunk/postgis/geography_inout.c	2017-12-11 15:04:01 UTC (rev 16143)
@@ -638,8 +638,7 @@
 	/* Recalculate the boxes after re-setting the geodetic bit */
 	lwgeom_set_geodetic(lwgeom, false);
-	lwgeom_drop_bbox(lwgeom);
-	lwgeom_add_bbox(lwgeom);
+	lwgeom_refresh_bbox(lwgeom);
 	/* We want "geometry" to think all our "geography" has an SRID, and the
 	   implied SRID is the default, so we fill that in if our SRID is actually unknown. */
Modified: trunk/postgis/lwgeom_functions_basic.c
--- trunk/postgis/lwgeom_functions_basic.c	2017-12-11 14:27:54 UTC (rev 16142)
+++ trunk/postgis/lwgeom_functions_basic.c	2017-12-11 15:04:01 UTC (rev 16143)
@@ -2632,8 +2632,7 @@
 	/* COMPUTE_BBOX TAINTING */
 	if ( lwgeom->bbox )
 	ret = geometry_serialize(lwgeom);
Modified: trunk/postgis/lwgeom_transform.c
--- trunk/postgis/lwgeom_transform.c	2017-12-11 14:27:54 UTC (rev 16142)
+++ trunk/postgis/lwgeom_transform.c	2017-12-11 15:04:01 UTC (rev 16143)
@@ -55,30 +55,27 @@
 	output_srid = PG_GETARG_INT32(1);
 	if (output_srid == SRID_UNKNOWN)
-		elog(ERROR,"%d is an invalid target SRID",SRID_UNKNOWN);
+		elog(ERROR, "%d is an invalid target SRID", SRID_UNKNOWN);
 		PG_RETURN_NULL();
+	/* Input SRID and output SRID are equal, noop */
+	if ( input_srid == output_srid )
+		PG_RETURN_POINTER(PG_GETARG_DATUM(0));
 	geom = PG_GETARG_GSERIALIZED_P_COPY(0);
 	input_srid = gserialized_get_srid(geom);
 	if ( input_srid == SRID_UNKNOWN )
 		PG_FREE_IF_COPY(geom, 0);
-		elog(ERROR,"Input geometry has unknown (%d) SRID",SRID_UNKNOWN);
+		elog(ERROR, "Input geometry has unknown (%d) SRID", SRID_UNKNOWN);
 		PG_RETURN_NULL();
-	 * If input SRID and output SRID are equal, return geometry
-	 * without transform it
-	if ( input_srid == output_srid )
-		PG_RETURN_POINTER(PG_GETARG_DATUM(0));
 	if ( GetProjectionsUsingFCInfo(fcinfo, input_srid, output_srid, &input_pj, &output_pj) == LW_FAILURE )
-		elog(ERROR,"Failure reading projections from spatial_ref_sys.");
+		elog(ERROR, "Failure reading projections from spatial_ref_sys.");
 		PG_RETURN_NULL();
@@ -90,8 +87,7 @@
 	/* Re-compute bbox if input had one (COMPUTE_BBOX TAINTING) */
 	if ( lwgeom->bbox )
 	result = geometry_serialize(lwgeom);
@@ -186,8 +182,7 @@
 	if ( lwgeom->bbox )
