[postgis-tickets] r16154 - Remove potentially non-deterministic tests to see if travis runs stabilize (per komzpa)
Paul Ramsey pramsey at cleverelephant.ca
Fri Dec 15 09:44:37 PST 2017
Author: pramsey
Date: 2017-12-15 09:44:37 -0800 (Fri, 15 Dec 2017)
New Revision: 16154
   trunk/regress/estimatedextent.sql
   trunk/regress/estimatedextent_expected
Modified: trunk/regress/estimatedextent.sql
--- trunk/regress/estimatedextent.sql	2017-12-15 14:51:34 UTC (rev 16153)
+++ trunk/regress/estimatedextent.sql	2017-12-15 17:44:37 UTC (rev 16154)
@@ -205,11 +205,11 @@
 insert into test (geom1, geom2) select st_makepoint(s, s), st_makepoint(2*s, 2*s) from generate_series(-100,100) s;
 select '4.a box',_postgis_index_extent('test', 'geom1');
 select '4.b box',_postgis_index_extent('test', 'geom2');
-delete from test;
-select '5.a bad-box',_postgis_index_extent('test', 'geom1');
-select '5.b bad-box',_postgis_index_extent('test', 'geom2');
-vacuum full test;
-select '6.a null', _postgis_index_extent('test', 'geom1');
-select '6.b null', _postgis_index_extent('test', 'geom2');
+-- delete from test;
+-- select '5.a bad-box',_postgis_index_extent('test', 'geom1');
+-- select '5.b bad-box',_postgis_index_extent('test', 'geom2');
+-- vacuum full test;
+-- select '6.a null', _postgis_index_extent('test', 'geom1');
+-- select '6.b null', _postgis_index_extent('test', 'geom2');
 drop table test cascade;
Modified: trunk/regress/estimatedextent_expected
--- trunk/regress/estimatedextent_expected	2017-12-15 14:51:34 UTC (rev 16153)
+++ trunk/regress/estimatedextent_expected	2017-12-15 17:44:37 UTC (rev 16154)
@@ -47,7 +47,3 @@
 3.b null|
 4.a box|BOX(-100 -100,100 100)
 4.b box|BOX(-200 -200,200 200)
-5.a bad-box|BOX(-100 -100,100 100)
-5.b bad-box|BOX(-200 -200,200 200)
-6.a null|
-6.b null|
