[postgis-tickets] [PostGIS] #3706: Use of deprecated function
PostGIS trac at osgeo.org
Mon Dec 18 03:20:51 PST 2017
  Reporter:  postgispaul  |      Owner:  robe
      Type:  defect       |     Status:  closed
  Priority:  high         |  Milestone:  PostGIS 2.3.3
 Component:  postgis      |    Version:  2.3.x
Resolution:  worksforme   |   Keywords:
Comment (by postgispaul):
 I know it's been a while, but now I'm able to really check what's going
 on.
 Now I've updated the lot to postgres 10 and postgis 2.4.2 and still have
 the same issue.
 If I install a new cluster with postgres 10 and postgis 2.4.2 it works
 without warning, so indeed it's an update issue.
 I'm not able to remove postgis and add a fresh one (a lot of geometry is
 used), and I'm a bit worried that I'm missing some more bugfixes than this
 one.
 Is there a way to redefine all functions to their newest spec?
 Also, I have tried to find where the ST_Extent function is defined (so I
 can patch it manually) but I wasn't able to find it's definition...
 P.S. and you're right about the typo :)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3706#comment:4>
