[postgis-tickets] [PostGIS] #3944: [PATCH] Update spatial_ref_sys.sql to EPSG v9.2
PostGIS trac at osgeo.org
Mon Dec 18 07:19:18 PST 2017
  Reporter:  rouault  |      Owner:  pramsey
      Type:  patch    |     Status:  reopened
  Priority:  medium   |  Milestone:  PostGIS 2.5.0
 Component:  postgis  |    Version:  2.4.x
Resolution:           |   Keywords:
Comment (by rouault):
 > You say "manual hacking" with such distaste :)
 Yes, because otherwise we have inconsistent conversion rules in the stack,
 and people will not replicate the same results when using ST_Transform()
 in PostGIS vs in GDAL, proj commandlines or with QGIS.
 > Where would an upstream ticket go, geotiff or gdal?
 Likely GDAL. We should probably use data/coordinate_operation.csv and
 data/coordinate_operation_parameter_value.csv to find the appropriate
 grid. But the subject is non-trivial since proj4 4.x only support DatumA
 <--> WGS84 <---> DatumB conversions, whereas a lot of grids implement
 DatumA <--> DatumB conversions. proj 5 will better handle this
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3944#comment:9>
