[postgis-tickets] [PostGIS] #3945: winnies svn hooks not working
PostGIS trac at osgeo.org
Wed Dec 20 20:53:37 PST 2017
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  closed
  Priority:  blocker    |  Milestone:  PostGIS 2.4.3
 Component:  buildbots  |    Version:  2.4.x
Resolution:  fixed      |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 Issue happened when I switched winnie to proxy her own traffick.
 I'm using Caddy for proxying and by default only tls1.1 and tls1.2 were
 enabled for security reasons.  I had to add tls1.0 otherwise when doing
 curl call from tracsvn
 to https://winnie.postgis.net:444
 would yield this error:
  error:1407742E:SSL routines:SSL23_GET_SERVER_HELLO:tlsv1 alert protocol
 version
 anyway we know the tracvm is old and needs to be upgraded, perhaps when we
 get new hardware I'll bring it up again on SAC
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3945#comment:1>
