[postgis-tickets] [PostGIS] #3949: Infinite (?) loop in distance calculation
PostGIS trac at osgeo.org
Fri Dec 22 04:15:31 PST 2017
  Reporter:  pramsey  |      Owner:  nicklas
      Type:  defect   |     Status:  assigned
  Priority:  high     |  Milestone:  PostGIS 2.4.3
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by nicklas):
 I agree.
 But worst case is different for different methods.
 The example Paul provided here is among the worst cases for the algorithm
 we use now (when bboxes doesn't overlap, then it falls back to brute
 force)
 If the shoreline of both geometries would have been convex it would have
 been quite a lot faster, but now one is concave and all points in the
 concave part needs to be tested more or less.
 So for this case that is a pain for that algorithm it loses the battle
 with about 1.08 (79 sec vs 85 sec)
 But for the case with the same geometries further away it wins by using
 approx 0.04 of the time brute force method uses. And with the case when we
 turn the other side of the geometries against each other it wins by using
 approx 0.0005 of the brute force method.
 So in this case I think the 8 % worse result in some cases is ok. BUT, the
 problem is that it is unpredictable. Users will like Paul think that
 something is wrong.
 But we have lived with this code now since 2010 and I don't think there
 have been many posts on the list about that issue. But I have hit that
 wall a few times myself making queries much slower than I expect. And it
 can be very frustrating when testing a sample to get an idea of the query
 time and then it takes 100 times longer.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3949#comment:9>
