[postgis-tickets] [PostGIS] #3950: PostGIS trunk doesn't work against 9.5
PostGIS trac at osgeo.org
Fri Dec 22 20:38:06 PST 2017
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 2.5.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Description changed by robe:
Old description:
> I guess we can't use the ALLOC small sizes for 9.5
> This is showing on winnie's 9.5 and 9.4 tests
> prototypes  -c -o lwgeom_transform.o lwgeom_transform.c
> lwgeom_transform.c: In function 'AddToPROJ4SRSCache':
> lwgeom_transform.c:545:42: error: 'ALLOCSET_SMALL_SIZES' undeclared
> (first use in this function)
>                                           ALLOCSET_SMALL_SIZES);
> lwgeom_transform.c:545:42: note: each undeclared identifier is reported
> only once for each function it appears in
> lwgeom_transform.c:545:42: error: too few arguments to function
> 'AllocSetContextCreate'
> In file included from lwgeom_transform.c:18:0:
> E:/jenkins/postgresql/rel/pg9.5w64gcc48/include/server/utils/memutils.h:131:22:
> note: declared here
>  extern MemoryContext AllocSetContextCreate(MemoryContext parent,
> Makefile:61: recipe for target 'lwgeom_transform.o' failed
> make[1]: *** [lwgeom_transform.o] Error 1
> make[1]: Leaving directory '/projects/postgis/branches/2.5/libpgcommon'
> GNUmakefile:16: recipe for target 'all' failed
> make: *** [all] Error 1
New description:
 This is showing on winnie's 9.5  tests
 lwgeom_transform.c:545:42: error: 'ALLOCSET_SMALL_SIZES' undeclared (first
 note: declared here
 So I guess 1 of two options, we can IF DEF for 9.5 or just have 9.5 go
 down the yee old path like 9.4
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3950#comment:1>
