[postgis-tickets] r16189 - Change new cache behavior to require > 9.6 instead of > 9.5, the AllocSetContextCreate structure in 9.5 doesn't support ALLOCSET_SMALL_SIZES macro so would otherwise require more ugly ifdefing.
Regina Obe lr at pcorp.us
Wed Dec 27 07:23:29 PST 2017
Author: robe
Date: 2017-12-27 07:23:29 -0800 (Wed, 27 Dec 2017)
New Revision: 16189
   trunk/extensions/address_standardizer/std_pg_hash.c
   trunk/libpgcommon/lwgeom_transform.c
   trunk/postgis/lwgeom_geos_prepared.c
Closes #3950
Modified: trunk/extensions/address_standardizer/std_pg_hash.c
--- trunk/extensions/address_standardizer/std_pg_hash.c	2017-12-26 14:07:49 UTC (rev 16188)
+++ trunk/extensions/address_standardizer/std_pg_hash.c	2017-12-27 15:23:29 UTC (rev 16189)
@@ -113,7 +113,7 @@
 static void
-#if POSTGIS_PGSQL_VERSION < 95
+#if POSTGIS_PGSQL_VERSION < 96
 StdCacheDelete(MemoryContext context)
@@ -140,7 +140,7 @@
     DeleteStdHashEntry(context);
 static void
 StdCacheInit(MemoryContext context)
@@ -194,7 +194,7 @@
 #endif
-#endif /* POSTGIS_PGSQL_VERSION < 95 */
+#endif /* POSTGIS_PGSQL_VERSION < 96 */
 uint32
@@ -383,7 +383,7 @@
     DBG("Adding item to STD cache ('%s', '%s', '%s') index %d", lextab, gaztab, rultab, STDCache->NextSlot);
     STDMemoryContext = MemoryContextCreate(T_AllocSetContext, 8192,
                                            &StdCacheContextMethods,
                                            STDCache->StdCacheContext,
Modified: trunk/libpgcommon/lwgeom_transform.c
--- trunk/libpgcommon/lwgeom_transform.c	2017-12-26 14:07:49 UTC (rev 16188)
+++ trunk/libpgcommon/lwgeom_transform.c	2017-12-27 15:23:29 UTC (rev 16189)
@@ -89,7 +89,7 @@
 static void
 PROJ4SRSCacheDelete(MemoryContext context)
 #else
@@ -113,7 +113,7 @@
 	DeletePJHashEntry(context);
 static void
 PROJ4SRSCacheInit(MemoryContext context)
@@ -182,7 +182,7 @@
 #endif
  * PROJ4 projPJ Hash Table functions
@@ -534,7 +534,7 @@
 	POSTGIS_DEBUGF(3, "adding SRID %d with proj4text \"%s\" to query cache at index %d", srid, proj_str, PROJ4Cache->PROJ4SRSCacheCount);
 	PJMemoryContext = MemoryContextCreate(T_AllocSetContext, 8192,
 	                                      &PROJ4SRSCacheContextMethods,
 	                                      PROJ4Cache->PROJ4SRSCacheContext,
Modified: trunk/postgis/lwgeom_geos_prepared.c
--- trunk/postgis/lwgeom_geos_prepared.c	2017-12-26 14:07:49 UTC (rev 16188)
+++ trunk/postgis/lwgeom_geos_prepared.c	2017-12-27 15:23:29 UTC (rev 16189)
@@ -96,7 +96,7 @@
 static void
 PreparedCacheDelete(MemoryContext context)
 #else
@@ -125,7 +125,7 @@
 	DeletePrepGeomHashEntry(context);
 static void
 PreparedCacheInit(MemoryContext context)
@@ -192,7 +192,7 @@
 #endif
@@ -313,7 +313,7 @@
 	if ( ! prepcache->context_callback )
 		PrepGeomHashEntry pghe;
 		prepcache->context_callback = MemoryContextCreate(T_AllocSetContext, 8192,
 		                             &PreparedCacheContextMethods,
 		                             prepcache->context_statement,
