[postgis-tickets] [PostGIS] #3950: PostGIS trunk doesn't compile against 9.5
PostGIS trac at osgeo.org
Wed Dec 27 07:23:30 PST 2017
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 2.5.0
 Component:  postgis  |    Version:  trunk
Resolution:  fixed    |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"16189" 16189]:
 #!CommitTicketReference repository="" revision="16189"
 Change new cache behavior to require > 9.6 instead of > 9.5, the
 AllocSetContextCreate structure in 9.5 doesn't support
 ALLOCSET_SMALL_SIZES macro so would otherwise require more ugly ifdefing.
 Closes #3950
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3950#comment:5>
