[postgis-tickets] [PostGIS] #3962: debbie trunk (2.5 builds failing) for 9.6 and 9.5
PostGIS trac at osgeo.org
Wed Dec 27 10:37:49 PST 2017
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  closed
  Priority:  blocker    |  Milestone:  PostGIS 2.5.0
 Component:  buildbots  |    Version:  trunk
Resolution:  fixed      |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"16190" 16190]:
 #!CommitTicketReference repository="" revision="16190"
 Add 5 seconds sleep before attempt to drop regress database, to give pg
 time to start up in case not fully started.
 Closes #3962
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3962#comment:2>
