[postgis-tickets] r16188 - Weight-aware ST_GeometricMedian
Daniel Baston dbaston at gmail.com
Thu Dec 28 06:10:18 PST 2017
Thanks -- I will try to look at this within the next couple of days.
Dan
On Wed, Dec 27, 2017 at 10:40 AM, Darafei "Komяpa" Praliaskouski <
komzpa at gmail.com> wrote:
> Hi Dan,
> I'm sorry to have committed that change too fast.
> I was under impression that I've addresses all of the comments you've made
> on the code. Now I see that I replied not to all of them, but just had
> those hidden by github as underlying code changed according to the comment,
> and shown only in PR history.
> I've reopened PR so we can continue with review. I hope we can do that
> without a revert. (I need the math there to work well too, so it's not in
> my interest to ignore issues :)
> I'll start thread on size_t for counters on -dev.
> ср, 27 дек. 2017 г. в 17:25, Daniel Baston <dbaston at gmail.com>:
>> Given that this approaches a complete rewrite, I would have appreciated
>> the chance to review this before you committed it to trunk. The PR
>> currently has several open questions. This commit also makes some style
>> changes (size_t instead of int for counters is one) that should be brought
>> up on the dev list, so we can get a ticket to apply them globally if they
>> are desirable.
>> Dan
>> On Tue, Dec 26, 2017 at 9:07 AM, Darafei <komzpa at gmail.com> wrote:
>>> Author: komzpa
>>> Date: 2017-12-26 06:07:49 -0800 (Tue, 26 Dec 2017)
>>> New Revision: 16188
>>> Modified:
>>>    trunk/NEWS
>>>    trunk/doc/reference_measure.xml
>>>    trunk/liblwgeom/cunit/cu_algorithm.c
>>>    trunk/liblwgeom/lwgeom_median.c
>>> Log:
>>> Weight is to be supplied as M ordinate of individual points in
>>> MultiPoint.
>>> Bring lwgeom_median.c cunit test coverage to 100%.
>>> ST_GeometricMedian(fail_if_not_converged=false, max_iter=0)
>>> might give you weighted centroid, but that's not a promise.
>>> Closes #3954
>>> Closes https://github.com/postgis/postgis/pull/176
URL: <http://lists.osgeo.org/pipermail/postgis-tickets/attachments/20171228/4c48d818/attachment.html>
