[postgis-tickets] [PostGIS] #3700: test_kmeans fails on winnie often on 32-bit and sometimes on 64-bit runs, and travis sometimes
PostGIS trac at osgeo.org
Thu Dec 28 21:03:52 PST 2017
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  high     |  Milestone:  PostGIS 2.4.3
 Component:  postgis  |    Version:  2.3.x
Resolution:           |   Keywords:
Comment (by robe):
 yah that would be great.  Not sure how to move forward with that.
 BTW winnie's 64-bit on 2.5.0 failed
   Test: test_kmeans ...Makefile:86: recipe for target 'check' failed
 make[2]: *** [check] Segmentation fault
 make[2]: Leaving directory
 '/projects/postgis/branches/2.4/liblwgeom/cunit'
 Makefile:207: recipe for target 'check' failed
 make[1]: *** [check] Error 2
 make[1]: Leaving directory '/projects/postgis/branches/2.4/liblwgeom'
 GNUmakefile:16: recipe for target 'check' failed
 make: *** [check] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3700#comment:18>
