[postgis-tickets] [PostGIS] #3965: KMeans provides less than K	clusters
    trac at osgeo.org
    Fri Dec 29 05:36:33 PST 2017
  Reporter:  komzpa   |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  high     |  Milestone:  PostGIS 2.4.3
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Description changed by komzpa:
Old description:
> Clustering 100 distinct points into 100 clusters gets 96 clusters:
> select count(distinct cid) from
> (WITH
> points AS (
>     SELECT ST_MakePoint(x,y) geom from generate_series(1,5) x,
> generate_series(1,5) y
> SELECT ST_ClusterKMeans(geom, 25) over () AS cid, geom
> FROM points) z;
> The larger K is, the bigger losses are.
New description:
 Clustering 25 distinct points into 25 clusters gets 24 clusters:
 (WITH
 points AS (
 FROM points) z;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3965#comment:1>
