[postgis-tickets] [PostGIS] #3701: Escape double quotes issue in pgsql2shp
trac at osgeo.org
Thu Feb 2 07:23:27 PST 2017
Reporter: kalxas | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS PostgreSQL
Component: postgis | Version: 2.2.x
Keywords: |
On behalf of Sergej Dugokontov:
Error executing main scan query: ERROR: zero-length delimited identifier
at or near """"
LINE 1: DECLARE cur CURSOR FOR SELECT ""quoteColumn",ST_AsEWKB(ST_Se...
If I change sql to:
SELECT
c1 AS "geom",
c2 AS """""quoteColumn"
FROM t1
I got different error:
Error executing main scan query: ERROR: column ""quoteColumn" does not
exist
LINE 1: DECLARE cur CURSOR FOR SELECT """quoteColumn",ST_AsEWKB(ST_S...
HINT: Perhaps you meant to reference the column
"__pgsql2shp22020_tmp_table.""quoteColumn".
I use `pgsql2shp RELEASE: 2.2.1 (r14555)` on Ubuntu 16.04 LTS and don't
have any issues if column alias in sql doesn't contain double quotes.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3701>
