[postgis-tickets] [PostGIS] #3701: Escape double quotes issue in pgsql2shp
PostGIS trac at osgeo.org
Thu Feb 2 08:39:30 PST 2017
  Reporter:  kalxas   |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.3.3
 Component:  postgis  |    Version:  2.2.x
Resolution:           |   Keywords:
Comment (by robe):
 okay I tried again with this, which might be what you meant.
 I started off with a table that has quotes in column:
 So my dbf column ends up being quoteColumn.
 Anyrate, I think your quoting might still be off by a bit and seems like a
 waste of effort.
 I also tried this first creating a table:
 SELECT ST_SetSRID(ST_Point(1,2)::geometry,4326)  AS "geom", 1 AS
 """quoteColumn" INTO testq;
 Then outputing the table
 {{{  --run from psql
 Then I tried to export the table
 pgsql2shp -r -g geom -f testq pgr testq
 and it failed with your error.  So seems there is something wrong with our
 quote escaping logic.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3701#comment:3>
