[postgis-tickets] [PostGIS] #3661: Mapbox vector tile output support via ST_AsMVT
PostGIS trac at osgeo.org
Tue Feb 7 12:36:46 PST 2017
  Reporter:  Björn Harrtell  |      Owner:  robe
      Type:  enhancement     |     Status:  new
  Priority:  medium          |  Milestone:  PostGIS 2.4.0
 Component:  postgis         |    Version:  trunk
Resolution:                  |   Keywords:  history, mvt
Comment (by Björn Harrtell):
 As far as I know protobuf (C++) is only needed for the C version of the
 protobuf compiler which is only required for building. In error, I pointed
 you to the C++ protobuf compiler before - the needed package is
 protobuf-c-compiler which depends on protobuf.
 The configure variable only needs to point out protobuf-c. The configure
 scripts checks the PATH for existence of the protobuf compiler command
 (here
 https://github.com/postgis/postgis/blob/fee914f1174c1ab6869fbc9e23634fcd68a8455c/configure.ac#L947).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3661#comment:15>
