[postgis-tickets] [PostGIS] #3661: Mapbox vector tile output support via ST_AsMVT
PostGIS trac at osgeo.org
Tue Feb 7 18:19:52 PST 2017
  Reporter:  Björn Harrtell  |      Owner:  robe
      Type:  enhancement     |     Status:  new
  Priority:  medium          |  Milestone:  PostGIS 2.4.0
 Component:  postgis         |    Version:  trunk
Resolution:                  |   Keywords:  history, mvt
Comment (by robe):
 Success, debbie is now building with protobuf-c
  -------------- Dependencies --------------
   GEOS config:
 /var/lib/jenkins/workspace/geos/rel-3.7.0devw64/bin/geos-config
   GEOS version:         3.7.0dev
   GDAL config:          /var/lib/jenkins/workspace/gdal/rel-2.1w64/bin
 /gdal-config
   GDAL version:         2.1.3
   SFCGAL config:        /usr/bin/sfcgal-config
   SFCGAL version:       1.3.0
   PostgreSQL config:
 /var/lib/jenkins/workspace/pg/rel/pg9.6w64/bin/pg_config
   PostgreSQL version:   PostgreSQL 9.6.2
   PROJ4 version:        49
   Libxml2 config:       /usr/bin/xml2-config
   Libxml2 version:      2.9.4
   JSON-C support:       yes
   protobuf-c support:   yes
   PCRE support:         yes
   PostGIS debug level:  0
   Perl:                 /usr/bin/perl
  --------------- Extensions ---------------
 Now to work on winnie.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3661#comment:18>
