[postgis-tickets] [PostGIS] #3700: test_kmeans fails on winnie often on 32-bit and sometimes on 64-bit runs (was: test_kmeans fails on winnie often on 32-bit runs)
PostGIS trac at osgeo.org
Sun Feb 12 10:30:44 PST 2017
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  2.3.x
Resolution:           |   Keywords:
Comment (by robe):
 Okay this just happened on winnie's 64-bit trunk run so guess not limited
 to 32-bit. This is the first time I recall it happening on 64-bit.
  Test: test_kmeans ...Makefile:85: recipe for target `check' failed
 make[2]: *** [check] Error 255
 make[2]: Leaving directory
 `/projects/postgis/branches/2.4/liblwgeom/cunit'
 Makefile:205: recipe for target `check' failed
 make[1]: *** [check] Error 2
 make[1]: Leaving directory `/projects/postgis/branches/2.4/liblwgeom'
 GNUmakefile:16: recipe for target `check' failed
 make: *** [check] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3700#comment:6>
