[postgis-tickets] [PostGIS] #3708: within function gives wrong results
PostGIS trac at osgeo.org
Mon Feb 13 00:53:08 PST 2017
 Reporter:  gisdev1982  |      Owner:  pramsey
     Type:  defect      |     Status:  new
 Priority:  high        |  Milestone:  PostGIS PostgreSQL
Component:  postgis     |    Version:  1.5.X
 Keywords:              |
 Hi Team,
 While executing the following query it gives wrong results. This was
 tested in postgis version from 1.2.1 to 1.5.5. In all the versions it
 **Query is:**
 SELECT within(geomfromtext('POLYGON((61 34,66 34,66 31,61 31,61
 34))',101), geomfromtext('POLYGON((62 48,83 48,83 29,55 29,55 33,62
 48))',101))
 It gives me 'f' as result where as it should be 't'
 If I execute the same query by adding some precision as shown below it
 gives me correct result.
 SELECT within(geomfromtext('POLYGON((61 34,66.0000001 34,66 31,61 31,61
 48))',101))
 kindly help me how I can get the correct result without adding the
 precision.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3708>
