[postgis-tickets] [PostGIS] #3699: Nothing downloads edge, faces, featnames, or addr files
PostGIS trac at osgeo.org
Wed Feb 15 22:45:21 PST 2017
  Reporter:  EvanCarroll     |      Owner:  robe
      Type:  defect          |     Status:  closed
  Priority:  blocker         |  Milestone:  PostGIS 2.3.2
 Component:  tiger geocoder  |    Version:  2.3.x
Resolution:  invalid         |   Keywords:
Comment (by znmeb):
 So wait ... if I run the nation script before *generating* the state
 script, the state script will work? I generated the nation script, then
 the state script, then ran the nation script to completion, then ran the
 state script and FACES, FEATNAMES, EDGES and ADDR weren't downloaded.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3699#comment:15>
