[postgis-tickets] [PostGIS] #3699: Nothing downloads edge, faces, featnames, or addr files
PostGIS trac at osgeo.org
Wed Feb 15 23:15:07 PST 2017
  Reporter:  EvanCarroll     |      Owner:  robe
      Type:  defect          |     Status:  closed
  Priority:  blocker         |  Milestone:  PostGIS 2.3.2
 Component:  tiger geocoder  |    Version:  2.3.x
Resolution:  invalid         |   Keywords:
Comment (by znmeb):
 Replying to [comment:15 znmeb]:
 > So wait ... if I run the nation script before *generating* the state
 script, the state script will work? I generated the nation script, then
 the state script, then ran the nation script to completion, then ran the
 state script and FACES, FEATNAMES, EDGES and ADDR weren't downloaded.
 Yes ... in fact, that's exactly what happens! I ran the state script
 generator *after* the database was populated and now it has the wgets for
 the missing shapefiles. So the documentation should read:
 1. Generate the nation script.
 2. Run the nation script.
 3. Generate the state script.
 4. Run the state script.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3699#comment:17>
