[postgis-tickets] [PostGIS] #3718: Invalid edge (no two distinct vertices exist)
PostGIS trac at osgeo.org
Tue Feb 21 07:06:43 PST 2017
 Reporter:  Andreas Wicht                        |      Owner:  strk
     Type:  enhancement                          |     Status:  new
 Priority:  high                                 |  Milestone:  PostGIS
                                                 |  2.3.3
Component:  topology                             |    Version:  2.3.x
 Keywords:  topology, tolerance, 0-length, edge  |
 Picking up following conversation (10:47:49 - 12:02:32) on #postgis:
 http://irclogs.geoapt.com/postgis/%23postgis.2017-02-09.log
 I am getting following error message while updating geometries within a
 topology.
 SQL Error [XX000]: ERROR: Invalid edge (no two distinct vertices exist)
 Where: PL/pgSQL function
 topology.totopogeom(geometry,topology.topogeometry,double precision) line
 111 at FOR over SELECT rows
 Following subset of the data can be used to reproduce the error:
 #!sql
 create table test.mini (
     id serial,
     src text,
     geom geometry(Multipolygon,4326)
 -- fill the table
 insert into test.mini (src, geom)
     values
         ('orig', st_geomfromewkt('SRID=4326;MULTIPOLYGON(((-5.113
 50.2643862560647,-5.113006 50.264387,-5.114048 50.264377,-5.114106
 50.264376,-5.11425 50.264374,-5.114291 50.264374,-5.114854
 50.264367,-5.115803 50.264359,-5.115859 50.264359,-5.11626
 50.264356,-5.116537 50.264353,-5.116581 50.264353,-5.118384
 50.264338,-5.118422 50.264338,-5.118885 50.264334,-5.119122
 50.264332,-5.11915 50.264207,-5.119288 50.2636,-5.119185
 50.263454,-5.118613 50.263448,-5.118556 50.263293,-5.118641
 50.263161,-5.11872 50.263037,-5.11906 50.263071,-5.119224
 50.263074,-5.119273 50.263075,-5.119515 50.26308,-5.119295
 50.262249,-5.119283 50.262202,-5.119242 50.262048,-5.119339
 50.26202,-5.119398 50.262003,-5.120092 50.261803,-5.120125
 50.261794,-5.120956 50.261554,-5.120869 50.261412,-5.120516
 50.26083,-5.12029 50.260599,-5.120192 50.260499,-5.12009
 50.260394,-5.120005 50.260055,-5.119984 50.259972,-5.119871
 50.259712,-5.119971 50.259505,-5.120458 50.259197,-5.120363
 50.259127,-5.11921 50.258276,-5.118999 50.257862,-5.118948
 50.257652,-5.118934 50.257593,-5.125247 50.256854,-5.125631
 50.257041,-5.127288 50.25785,-5.127077 50.258466,-5.126626
 50.259523,-5.126434 50.259988,-5.126492 50.260494,-5.126249
 50.260532,-5.125334 50.260676,-5.123779 50.259652,-5.122835
 50.259806,-5.123177 50.260209,-5.123252 50.260297,-5.123723
 50.260438,-5.123965 50.26051,-5.12523 50.260692,-5.125194
 50.261171,-5.125172 50.261466,-5.125409 50.262131,-5.12543
 50.262461,-5.125433 50.262507,-5.125451 50.262781,-5.125472
 50.263103,-5.125343 50.263377,-5.125208 50.263666,-5.125185
 50.263703,-5.125167 50.263732,-5.124252 50.265221,-5.125725
 50.265752,-5.125814 50.265784,-5.125852 50.265798,-5.126139
 50.265901,-5.12669 50.266094,-5.127098 50.266236,-5.129076
 50.266928,-5.129183 50.266965,-5.129961 50.267237,-5.13
 50.267251,-5.131081 50.26763,-5.132104 50.268,-5.134811 50.268861,-5.1349
 50.2688832940013,-5.1349 50.2695,-5.113 50.2695,-5.113
 50.2643862560647)))')),
         ('orig', st_geomfromewkt('SRID=4326;MULTIPOLYGON(((-5.12523
 50.260692,-5.125334 50.260676,-5.126249 50.260532,-5.126492
 50.260494,-5.126434 50.259988,-5.126626 50.259523,-5.127077
 50.258466,-5.127288 50.25785,-5.125631 50.257041,-5.125247
 50.256854,-5.125119 50.256791,-5.124987 50.256727,-5.12285
 50.25617,-5.122946 50.25607,-5.123096 50.255991,-5.123756
 50.255915,-5.123967 50.255802,-5.123937 50.255409,-5.12404
 50.255148,-5.123956 50.25483,-5.124106 50.254415,-5.124191
 50.254237,-5.124236 50.254143,-5.124531 50.253528,-5.125362
 50.25229,-5.125764 50.251672,-5.125907 50.250856,-5.125861
 50.250695,-5.125753 50.250318,-5.12555616566265 50.25,-5.1349
 50.25,-5.1349 50.2688832940013,-5.134811 50.268861,-5.132104
 50.268,-5.131081 50.26763,-5.13 50.267251,-5.129961 50.267237,-5.129183
 50.266965,-5.129076 50.266928,-5.127098 50.266236,-5.12669
 50.266094,-5.126139 50.265901,-5.125852 50.265798,-5.125814
 50.265784,-5.125725 50.265752,-5.124252 50.265221,-5.125167
 50.263732,-5.125185 50.263703,-5.125208 50.263666,-5.125343
 50.263377,-5.125472 50.263103,-5.125451 50.262781,-5.125433
 50.262507,-5.12543 50.262461,-5.125409 50.262131,-5.125172
 50.261466,-5.125194 50.261171,-5.12523 50.260692)))')),
         ('orig',
 st_geomfromewkt('SRID=4326;MULTIPOLYGON(((-5.12555616566265
 50.25,-5.125753 50.250318,-5.125861 50.250695,-5.125907
 50.250856,-5.125764 50.251672,-5.125362 50.25229,-5.124531
 50.253528,-5.124236 50.254143,-5.124191 50.254237,-5.124106
 50.254415,-5.123956 50.25483,-5.12404 50.255148,-5.123937
 50.255409,-5.123967 50.255802,-5.123756 50.255915,-5.123096
 50.255991,-5.122946 50.25607,-5.12285 50.25617,-5.124987
 50.256727,-5.125119 50.256791,-5.125247 50.256854,-5.118934
 50.257593,-5.118948 50.257652,-5.118999 50.257862,-5.11921
 50.258276,-5.120363 50.259127,-5.120458 50.259197,-5.119971
 50.259505,-5.119871 50.259712,-5.119984 50.259972,-5.120005
 50.260055,-5.12009 50.260394,-5.120192 50.260499,-5.12029
 50.260599,-5.120516 50.26083,-5.120869 50.261412,-5.120956
 50.261554,-5.120125 50.261794,-5.120092 50.261803,-5.119398
 50.262003,-5.119339 50.26202,-5.119242 50.262048,-5.119283
 50.262202,-5.119295 50.262249,-5.119515 50.26308,-5.119273
 50.263075,-5.119224 50.263074,-5.11906 50.263071,-5.11872
 50.263037,-5.118641 50.263161,-5.118556 50.263293,-5.118613
 50.263448,-5.119185 50.263454,-5.119288 50.2636,-5.11915
 50.264207,-5.119122 50.264332,-5.118885 50.264334,-5.118422
 50.264338,-5.118384 50.264338,-5.116581 50.264353,-5.116537
 50.264353,-5.11626 50.264356,-5.115859 50.264359,-5.115803
 50.264359,-5.114854 50.264367,-5.114291 50.264374,-5.11425
 50.264374,-5.114106 50.264376,-5.114048 50.264377,-5.113006
 50.264387,-5.113 50.2643862560647,-5.113 50.25,-5.12555616566265
 50.25)),((-5.125334 50.260676,-5.12523 50.260692,-5.123965
 50.26051,-5.123723 50.260438,-5.123252 50.260297,-5.123177
 50.260209,-5.122835 50.259806,-5.123779 50.259652,-5.125334
 50.260676)))')),
         ('edited', st_geomfromewkt('SRID=4326;MULTIPOLYGON(((-5.121593
 50.260234,-5.124099 50.260207,-5.124068 50.258374,-5.12517
 50.258654,-5.126523 50.259773,-5.126434 50.259988,-5.126492
 50.260494,-5.126249 50.260532,-5.125334 50.260676,-5.125194
 50.264356,-5.116537 50.264353,-5.116581 50.264353,-5.117946
 50.264342,-5.118384 50.264338,-5.118422 50.264338,-5.118885
 50.264334,-5.120389 50.264424,-5.120417 50.264299,-5.120555
 50.263692,-5.120452 50.263546,-5.118613 50.263448,-5.118556
 50.263293,-5.118641 50.263161,-5.11872 50.263037,-5.11906
 50.263071,-5.119224 50.263074,-5.119273 50.263075,-5.119515
 50.26308,-5.119295 50.262249,-5.119283 50.262202,-5.119242
 50.262048,-5.119339 50.26202,-5.119398 50.262003,-5.120092
 50.261803,-5.120125 50.261794,-5.120956 50.261554,-5.120869
 50.261412,-5.120516 50.26083,-5.120486 50.260799,-5.12029
 50.260599,-5.120192 50.260499,-5.12009 50.260394,-5.120005
 50.260055,-5.119984 50.259972,-5.119871 50.259712,-5.119971
 50.259505,-5.120458 50.259197,-5.120363 50.259127,-5.11921
 50.258276,-5.120889 50.257364,-5.122878 50.258209,-5.121593
 50.260234)))')),
         ('edited', st_geomfromewkt('SRID=4326;MULTIPOLYGON(((-5.125194
 50.261171,-5.125334 50.260676,-5.126249 50.260532,-5.126492
 50.260494,-5.126434 50.259988,-5.126523 50.259773,-5.126626
 50.259523,-5.127077 50.258466,-5.127288 50.25785,-5.125631
 50.257041,-5.125247 50.256854,-5.125119 50.256791,-5.124987
 50.256727,-5.12285 50.25617,-5.122946 50.25607,-5.123096
 50.255991,-5.123756 50.255915,-5.123967 50.255802,-5.123937
 50.255409,-5.12404 50.255148,-5.123956 50.25483,-5.124106
 50.254415,-5.124191 50.254237,-5.124236 50.254143,-5.124531
 50.253528,-5.125362 50.25229,-5.125764 50.251672,-5.125907
 50.250856,-5.125861 50.250695,-5.125753 50.250318,-5.12555616566265
 50.25,-5.1349 50.25,-5.1349 50.2688832940013,-5.134811 50.268861,-5.132104
 50.261466,-5.125194 50.261171)))')),
         ('edited', st_geomfromewkt('SRID=4326;MULTIPOLYGON(((-5.126523
 50.259773,-5.125554 50.258972,-5.12517 50.258654,-5.124068
 50.258374,-5.124099 50.260207,-5.121593 50.260234,-5.122878
 50.258209,-5.120889 50.257364,-5.11921 50.258276,-5.120363
 50.259127,-5.120458 50.259197,-5.119971 50.259505,-5.119871
 50.259712,-5.119984 50.259972,-5.120005 50.260055,-5.12009
 50.260394,-5.120192 50.260499,-5.12029 50.260599,-5.120486
 50.260799,-5.120516 50.26083,-5.120869 50.261412,-5.120956
 50.263448,-5.120452 50.263546,-5.120555 50.263692,-5.120417
 50.264299,-5.120389 50.264424,-5.118885 50.264334,-5.118422
 50.256727,-5.125119 50.256791,-5.125247 50.256854,-5.125631
 50.259523,-5.126523 50.259773)))'))
 -- select topology.dropTopology('topo_test_mini');
 -- create the topology
 select topology.CreateTopology('topo_test_mini',
                                4326);
 -- add the topogeom column
 select topology.AddTopoGeometryColumn('topo_test_mini',
                                       'test',
                                       'mini',
                                       'topo_geom',
                                       'POLYGON');
 -- import the polygons to the topology which represent the status of the
 topology before the geometries were edited
 update test.mini
 set topo_geom = topology.toTopoGeom(geom, 'topo_test_mini', 1, 1e-6)
 where src = 'orig';
 topology after the geometries were edited - the error will occur here
 update test.mini
 where src = 'edited';
 PostGIS Version:
 `POSTGIS="2.3.2 r15302" GEOS="3.5.0-CAPI-1.9.0 r4084" PROJ="Rel. 4.9.2, 08
 September 2015" GDAL="GDAL 1.11.3, released 2015/09/16" LIBXML="2.9.3"
 LIBJSON="0.11.99" (core procs from "2.3.1 r15264" need upgrade) TOPOLOGY
 (topology procs from "2.3.1 r15264" need upgrade) RASTER (raster procs
 from "2.3.1 r15264" need upgrade)`
 Would there be implications which speak against allowing line-segments
 with a length of 0?
 How else **besides** reducing the tolerance (e.g. to 1e-7) could one deal
 with such a problem? In my test data set this error occurs more than once.
 As this represents a real world example I am worried, that this might
 actually be a really common error to happen.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3718>
