[postgis-tickets] [PostGIS] #3720: geobuf regress error on debbie and winnie
PostGIS trac at osgeo.org
Mon Feb 27 14:30:21 PST 2017
  Reporter:  robe     |      Owner:  Björn Harrtell
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  2.3.x
Resolution:           |   Keywords:
Comment (by robe):
 Would it be possible to spit out the version as part of configure like we
 have for others or is that really tricky.
  -------------- Dependencies --------------
   GEOS config:
 /var/lib/jenkins/workspace/geos/rel-3.7.0devw64/bin/geos-config
   GEOS version:         3.7.0dev
   GDAL config:          /var/lib/jenkins/workspace/gdal/rel-2.1w64/bin
 /gdal-config
   GDAL version:         2.1.3
   SFCGAL config:        /usr/bin/sfcgal-config
   SFCGAL version:       1.3.0
   PostgreSQL config:
 /var/lib/jenkins/workspace/pg/rel/pg9.6w64/bin/pg_config
   PostgreSQL version:   PostgreSQL 9.6.2
   PROJ4 version:        49
   Libxml2 config:       /usr/bin/xml2-config
   Libxml2 version:      2.9.4
   JSON-C support:       yes
   protobuf-c support:   yes
   PCRE support:         yes
   PostGIS debug level:  0
   Perl:                 /usr/bin/perl
 I forget which apt packages I installed on debbie - it's all a fog.
 I know on winnie, since I had to compile that from scratch, I used:
 protobuf-2.6.1 and protobuf-c-1.1.1
 Though winnie is on windows, she's exhibiting the same error, so presume
 it must be an issue with that combination as well.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3720#comment:11>
