[postgis-tickets] [PostGIS] #3720: geobuf regress error on debbie and winnie
PostGIS trac at osgeo.org
Tue Feb 28 08:08:57 PST 2017
  Reporter:  robe     |      Owner:  Björn Harrtell
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  2.3.x
Resolution:           |   Keywords:
Comment (by Björn Harrtell):
 Good enough for now. I will look into getting version numbers out in the
 dependency summary. It's a bit messy as the C lib has a transitive
 dependency on the C++ lib. I've got libprotobuf-c 1.2.1 and libprotobuf
 3.0.0 on my system so it seems you got the same at Debbie and I should
 look probably elsewhere to explain the problem.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3720#comment:13>
