[postgis-tickets] [PostGIS] #3675: Relationship functions not using an index in some cases
PostGIS trac at osgeo.org
Thu Jan 5 11:51:02 PST 2017
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 2.3.2
 Component:  postgis  |    Version:  2.3.x
Resolution:           |   Keywords:
Comment (by robe):
 In [changeset:"15281" 15281]:
 #!CommitTicketReference repository="" revision="15281"
 Set cost back to 1 for functions that return a geometry
 A higher cost has the side-effect of making the planner
 think when used in conjunction with relate constructs like ST_Intersects
 it's cheaper to compute the geometry once rather
 than compute twice and break into an index and non-index call.
 References #3675 for PostGIS 2.4
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3675#comment:12>
