[postgis-tickets] [PostGIS] #3649: knn_recheck regress failing under PostgreSQL 10 devel
PostGIS trac at osgeo.org
Fri Jan 6 20:23:47 PST 2017
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:  postgresql 10
Changes (by robe):
 * version:  2.3.x => trunk
Comment:
 Okay just checked on PostgreSQL recheck and looks like it's still an
 issue. I was hoping it would resolve itself or latest change to
 box2df_distance would resolve things, but alas still an issue.
  Last run which occurred after pramsey r15283 patch to fix #3418 looks
 like this:
 https://debbie.postgis.net/view/PostGIS/job/PostGIS_Regress_PGDEV_Weekly/3004/consoleFull
 PostgreSQL 10devel on x86_64-pc-linux-gnu, compiled by gcc (Debian
 5.2.1-22) 5.2.1 20151010, 64-bit
   Postgis 2.4.0dev - r15283 - 2017-01-06 22:04:03
   scripts 2.4.0dev r15283
   GEOS: 3.6.2dev-CAPI-1.10.2 r4324
   PROJ: Rel. 4.9.2, 08 September 2015
   SFCGAL: 1.3.0
  knn_recheck .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_4_pg10.0w64/test_94_diff)
 --- knn_recheck_expected        2017-01-01 03:28:18.511591903 +0000
 /var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_4_pg10.0w64/test_94_out
 2017-01-06 22:07:03.409251996 +0000
 @@ -13,8 +13,8 @@
  #3|1|147|9.6598|9.6598
  #3|1|291|10.8780|10.8780
  #3|1|292|13.4929|13.4929
 -#3|500003|500004|1447.7424|1447.7424
  #3|500003|500002|1447.7424|1447.7424
 +#3|500003|500004|1447.7424|1447.7424
  #3|500003|500001|3423.4486|3423.4486
  #3|500003|500005|3423.4486|3423.4486
  #3|500003|22837|5123.7770|5123.7770
 @@ -59,7 +59,7 @@
  #2g|30695|21264.3654|21264.3654
  #2g|30512|25313.2118|25313.2118
  #3g|1000|t
 -#3g|2614|t
 +#3g|2614|f
  #3g|500000|t
  #1g|500000|0.0000|0.0000
  #1g|600003|69974.6935|69974.6935
 @@ -72,7 +72,7 @@
  #3g|1000|t
 -#3g|2614|t
 +#3g|2614|f
  #3g|500000|t
  #1nd-3|290|260.6797|260.6797
  #1nd-3|287|264.3000|264.3000
 @@ -89,10 +89,10 @@
  #3nd-3|1|294|9.6598|9.6598
  #3nd-3|1|582|10.8780|10.8780
  #3nd-3|1|583|13.4929|13.4929
 -#3nd-3|500003|500004|1448.3262|1448.3262
  #3nd-3|500003|500002|1448.3262|1448.3262
 -#3nd-3|500003|500001|3424.9088|3424.9088
 +#3nd-3|500003|500004|1448.3262|1448.3262
  #3nd-3|500003|500005|3424.9088|3424.9088
 +#3nd-3|500003|500001|3424.9088|3424.9088
  #3nd-3|500003|45674|5153.7747|5153.7747
  #3nd-3|600001|600002|0.0000|0.0000
  #3nd-3|600001|9752|54.2730|54.2730
 so no change as far as I can see.  We'll probably have to start
 investigating if the issue is on our end or the PostgreSQL 10 code end
 since 10 will be out in another 7 months or so.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3649#comment:3>
