[postgis-tickets] [PostGIS] #3686: perl upgrade scripts make DO check more robust to handle named $something$
PostGIS trac at osgeo.org
Tue Jan 17 13:51:29 PST 2017
  Reporter:  robe     |      Owner:  strk
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  2.3.x
Resolution:           |   Keywords:
Comment (by strk):
 But then we'd be unable to test-before-install.
 Is any new PostgreSQL version supporting that yet ?
 Our least-required-version of PostgreSQL must support that
 before we can even think of dropping the script-based install method.
 (although there might be other limits, like need to have access on the
 server,
 which script-based is still good with)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3686#comment:7>
