[postgis-tickets] [PostGIS] #3690: ST_AsGeoJSON can produce invalid geometry collections
PostGIS trac at osgeo.org
Sat Jan 21 19:32:23 PST 2017
  Reporter:  jyutzler  |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 2.3.2
 Component:  postgis   |    Version:  2.3.x
Resolution:            |   Keywords:
Comment (by robe):
 well our processing of empty geometry collections seems okay:
 SELECT ST_AsGeoJSON('GEOMETRYCOLLECTION EMPTY'::geometry);
 -- yields--
 {"type":"GeometryCollection","geometries":[]}
 And ingesting the above with null is invalid:
 SELECT ST_GeomFromGeoJSON('{"type":"GeometryCollection",
 "geometries":null}');
 -- yields
 ERROR:  Unable to find 'geometries' in GeoJSON string
 Is the "geometry: part something you are getting back?  If getting back
 I'm assuming that is being tacked on by some post processor you have going
 and not part of what PostGIS is doing.  If so your post processor might
 also be converting [] to nulls.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3690#comment:2>
