[postgis-tickets] [PostGIS] #3683: Unable to update postgis after postgres pg_upgrade going from < 9.5 to pg > 9.4
PostGIS trac at osgeo.org
Sat Jan 21 23:51:13 PST 2017
9.4
  Reporter:  gregburek   |      Owner:  robe
      Type:  defect      |     Status:  closed
  Priority:  blocker     |  Milestone:  PostGIS 2.3.2
 Component:              |    Version:  2.3.x
  build/upgrade/install  |   Keywords:  pg_upgrade extension update
Resolution:  fixed       |  lifecycle
Changes (by robe):
 * cc: gregburek (added)
Comment:
 Greg,
 When you get a chance, can you test this out.
 I tested by
 Installing PostGIS 2.3.2dev on PostgreSQL 9.4 server (this ends up not
 including the new brin operators).
 CREATE EXTENSION postgis VERSION "2.3.2dev";
 Then used pg_upgrade to migrate this to PostgreSQL 9.6.1
 Once up, I ran:
 ALTER EXTENSION postgis UPDATE TO "2.3.2devnext";
 I verified after running the update step that I now have the brin
 operators, classes, and families.
 Since I'm not using any new constructs, I expect it to work for PostgreSQL
 9.2+
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3683#comment:6>
