[postgis-tickets] [PostGIS] #3699: Nothing downloads edge, faces, featnames, or addr files
PostGIS trac at osgeo.org
Thu Jan 26 08:38:27 PST 2017
  Reporter:  EvanCarroll     |      Owner:  robe
      Type:  defect          |     Status:  closed
  Priority:  blocker         |  Milestone:  PostGIS 2.3.2
 Component:  tiger geocoder  |    Version:  2.3.x
Resolution:  invalid         |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => invalid
Comment:
 Okay I was able to replicate your problem.  I think what you missed doing
 is running the nationscript first as noted in instructions here:
 http://postgis.net/docs/manual-2.3/postgis_installation.html#install_tiger_geocoder_extension
 For county files the wget figures out which files to load for a state
 based on the cousub table, which is loaded by the nationscript load.
 People always seem to screw that up, so I should do something to clarify
 it.  Like put in big bold red -- DO THIS FIRST before you do anything
 else.
 and also clarify you only need to do the nationscript load first.
 Documentation patch highly welcome if you can explain this better.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3699#comment:8>
