[postgis-tickets] [PostGIS] #3699: Nothing downloads edge, faces, featnames, or addr files
PostGIS trac at osgeo.org
Thu Jan 26 08:48:47 PST 2017
  Reporter:  EvanCarroll     |      Owner:  robe
      Type:  defect          |     Status:  closed
  Priority:  blocker         |  Milestone:  PostGIS 2.3.2
 Component:  tiger geocoder  |    Version:  2.3.x
Resolution:  invalid         |   Keywords:
Comment (by robe):
 1) Yes the FTP blacklists too.  But what it does on the fTP is more
 annoying. It just keeps you hanging there for days authenticating.
 At least the www bows out with an error.
 It would be really nice if there were tiger mirrors setup for this kind of
 thing
 2) Yah I suspect the nationscript failed for some reason.  I had the same
 output until I ran the nationscript.
 If nationscript runs successfully,
 SELECT * FROM tiger.county_all_lookup;
 should have data.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3699#comment:11>
