[postgis-tickets] r15295 - Fix for 32-bit lwprint to support ST_AsLatLonText
Regina Obe lr at pcorp.us
Fri Jan 27 20:10:49 PST 2017
Author: robe
Date: 2017-01-27 20:10:49 -0800 (Fri, 27 Jan 2017)
New Revision: 15295
   branches/2.3/liblwgeom/lwprint.c
References #3688 for PostGIS 2.3.2
Modified: branches/2.3/liblwgeom/lwprint.c
--- branches/2.3/liblwgeom/lwprint.c	2017-01-25 23:46:00 UTC (rev 15294)
+++ branches/2.3/liblwgeom/lwprint.c	2017-01-28 04:10:49 UTC (rev 15295)
@@ -106,6 +106,8 @@
 	int sec_dec_digits = 0;
 	int sec_piece = -1;
+	int round_pow = 0;
 	int format_length = ((NULL == format) ? 0 : strlen(format));
 	char * result;
@@ -313,8 +315,8 @@
 	degrees = val;
 	if (min_digits > 0)
-		degrees = (long)degrees;
-		minutes = fmod(val * 10, 10) * 6;
+		/* Break degrees to integer and use fraction for minutes */
+		minutes = modf(val, &degrees) * 60;
 	if (sec_digits > 0)
@@ -322,8 +324,17 @@
 			lwerror("Bad format, cannot include seconds (SS.SSS) without including minutes (MM.MMM).");
-		minutes = (long)minutes;
-		seconds = (val - (degrees + (minutes / 60))) * 3600;
+		seconds = modf(minutes, &minutes) * 60;
+		if (sec_piece >= 0)
+			/* See if the formatted seconds round up to 60. If so, increment minutes and reset seconds. */
+			round_pow = pow(10, sec_dec_digits);
+			if (floorf(seconds * round_pow) / round_pow >= 60)
+				minutes += 1;
+				seconds = 0;
 	/* Handle the compass direction.  If not using compass dir, display degrees as a positive/negative number. */
