[postgis-tickets] [PostGIS] #3700: test_kmeans fails on winnie often on 32-bit runs
PostGIS trac at osgeo.org
Tue Jan 31 10:00:15 PST 2017
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  2.3.x
Resolution:           |   Keywords:
Comment (by strk):
 No, but the lack of diff output suggests to me that there's no difference
 between expected and obtained output, thus the error must be in the
 run_test
 script itself. Can you try to run it in isolation on that machine, against
 the specific offending testcase ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3700#comment:4>
