[postgis-tickets] r15475 - turn off interrupt tests on winnie. Causing 32-bit to fail.
Regina Obe lr at pcorp.us
Wed Jul 5 01:00:02 PDT 2017
Author: robe
Date: 2017-07-05 01:00:02 -0700 (Wed, 05 Jul 2017)
New Revision: 15475
   trunk/ci/winnie/regress_postgis.sh
Modified: trunk/ci/winnie/regress_postgis.sh
--- trunk/ci/winnie/regress_postgis.sh	2017-07-01 06:49:42 UTC (rev 15474)
+++ trunk/ci/winnie/regress_postgis.sh	2017-07-05 08:00:02 UTC (rev 15475)
@@ -92,7 +92,7 @@
 	#BOOST_VER_WU=1_49_0
 	export BOOST_VER_WU=1_53_0
 	export PATH="${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/boost/rel-${BOOST_VER_WU}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
 CPPFLAGS="-I${PGPATH}/include -I${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/include" \
 LDFLAGS="-L${PGPATH}/lib -L${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/lib" ./configure \
   --host=${MINGHOST} --with-xml2config=${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin/xml2-config \
@@ -106,7 +106,8 @@
   --with-gui --with-gettext=no \
   --with-protobufdir=${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE} \
   --with-sfcgal=${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/sfcgal-config \
-  --with-pcredir=${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}
+  --with-pcredir=${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE} \
+  --without-interrupt-tests
 elif [ "$POSTGIS_MAJOR_VERSION" == "2" ] ; then
@@ -120,6 +121,7 @@
   --with-jsondir=${MINGPROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE} \
   --with-libiconv=${PROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE} \
   --with-xsldir=${PROJECTS}/docbook/docbook-xsl-1.76.1 \
 else
@@ -162,14 +164,14 @@
  cp -r extensions/*/sql/* ${PGPATHEDB}/share/extension
  cp -r extensions/*/*.control ${PGPATHEDB}/share/extension
  cp -r extensions/*/*.dll ${PGPATHEDB}/lib
  make check RUNTESTFLAGS="--extension -v"
  ##test address standardizer
  cd ${POSTGIS_SRC}
  cd extensions/address_standardizer
  make installcheck
  ##test tiger geocoder
  cd ${POSTGIS_SRC}
  cd extensions/postgis_tiger_geocoder
