[postgis-tickets] [PostGIS] #3783: OSS FUZZ entry points
PostGIS trac at osgeo.org
Mon Jul 10 12:35:34 PDT 2017
 Reporter:  robe     |      Owner:  robe
     Type:  defect   |     Status:  assigned
 Priority:  medium   |  Milestone:  PostGIS 2.4.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 Detailed in Even's note sent to mailing list:
 https://lists.osgeo.org/pipermail/postgis-devel/2017-July/026216.html
 repeated for completeness:
 I've prototyped an integration of liblwgeom from PostGIS repository with
 oss-fuzz.
 Quoting https://github.com/google/oss-fuzz/ ,
 Fuzz testing is a well-known technique for uncovering various kinds of
 programming errors in software.
 Many of these detectable errors (e.g. buffer overflow) can have serious
 security implications.
 We successfully deployed guided in-process fuzzing of Chrome components
 and found hundreds of
 security vulnerabilities and stability bugs. We now want to share the
 experience and the
 service with the open source community.
 In cooperation with the Core Infrastructure Initiative, OSS-Fuzz aims to
 make common
 open source software more secure and stable by combining modern fuzzing
 techniques
 and scalable distributed execution.
 GDAL and proj.4 have joined oss-fuzz, for a few weeks  and this is really
 efficient. I've fixed between 300 and 400 bugs in GDAL...
 So I just gave it a try with PostGIS, concentrating on liblwgeom, since it
 builds nicely in oss-fuzz environment
 (plain "make" in top repository fails in oss-fuzz from some reason I
 haven't investigated)
 As an example, I've created 2 fuzzers, one for lwgeom_from_wkb() and the
 other one for lwgeom_from_wkt().
 More could be done, based on those examples. Left as an exercice to other
 developers.
 Integration of a software with oss-fuzz is made of 2 parts:
 - fuzzer entry points must be in the project repository :
 https://github.com/rouault/postgis/tree/ossfuzz/fuzzers
 - a metadata file (project.yaml), a Dockerfile (download needed packages &
 PostGIS source code) and
 a "bootstrap" build.sh script  must be integrated in OSS-Fuzz own repo too
 https://github.com/rouault/oss-fuzz/tree/postgis/projects/postgis
 For now, I've done this in my own postgis and ossz-fuzz git forks as you
 can see, but ultimately if the
 project agrees we should merge this into their respective official repos.
 But pending that, you can already try this stuff locally
 Make sure you have Docker installed
 git clone  --branch postgis https://github.com/rouault/oss-fuzz
 cd oss-fuzz
 Build the Docker image:
 python infra/helper.py build_image postgis
 Build PostGIS and the fuzzer programs with the address sanitizer
 python infra/helper.py build_fuzzers --sanitizer address postgis
 Run one of the fuzzer (you can try with wkt_import_fuzzer too)
 python infra/helper.py run_fuzzer postgis wkb_import_fuzzer
 My local experiments show that lwgeom_from_wkt() seems to be rather
 robust,
 but lwgeom_from_wkb() has a few bugs. For the record, I found and fixed
 (in my fork) this memory leak
 (memory leak = leak in a case where lw_error() is not called) in
 https://github.com/rouault/postgis/commit/cf179396b719223653eee56a01189339e0abcc0d
 There's also a heap buffer overflow it just detected in
 ptarray_from_wkb_state /src/postgis/liblwgeom/lwin_wkb.c:367
 So if the community is interested in a closer integration in OSS Fuzz,
 next steps are :
 1) someone with PostGIS commit rights merges
 https://github.com/rouault/postgis/commit/0181a28ab01764b4e6d11a5d2ffe7edce96498c6
 into PostGIS SVN (as well as the bug fix
 while you are it)
 2) interested core PostGIS developers give me a @gmail.com email, so I add
 it in
 fuzz/blob/postgis/projects/postgis/project.yaml
 This way they will then have access to the bug reports that are embargoed
 for
 90 days (or 30 days after OSS Fuzz has found them to be fixed)
 3) I then modify https://github.com/rouault/oss-
 fuzz/blob/postgis/projects/postgis/Dockerfile to
 point to PostGIS official github mirror instead of my fork
 4) I then submit a pull request to https://github.com/google/oss-fuzz/
 with my
 https://github.com/rouault/oss-fuzz postgis branch . They may accept or
 not the application, but I guess they will accept.
 If they don't, you can also play with it locally as I showed above. And
 this is strongly recommended
 to do so when adding a new fuzzer for example.
 5) once the project is accepted, monitor https://bugs.chromium.org/p/oss-
 fuzz/issues/list?q=postgis and fix the bugs !
 6) add more fuzzers. Hint: in PostGIS "fuzzers" directory, "make
 dummyfuzzers" to check that your fuzzer builds.
 Note: I don't volunteer to fix all bugs that will be found. I have already
 enough to do with GDAL... I wouldn't
 mind if someone wants to be the declared maintainer in oss-fuzz
 projects/postgis/project.yaml and projects/postgis/Dockerfile
 Note 2: if you look closely at
 https://github.com/rouault/postgis/blob/ossfuzz/fuzzers/wkb_import_fuzzer.cpp
 you will notice that it is a bit messy since it stubs GEOS and geod_
 symbols. This is due to the fact
 that OSS-Fuzz requires that the fuzzer programs are completely statically
 linked, and Ubuntu doesn't ship
 with static builds of geos (actually just libgeos.a but no libgeos_c.a) as
 far as I can see.
 All this could be improved by adding a download of GEOS source code in
 fuzz/blob/postgis/projects/postgis/Dockerfile and building it manually in
 https://github.com/rouault/oss-fuzz/blob/postgis/projects/postgis/build.sh
 Thoughts ?
 Even
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3783>
