[postgis-tickets] [PostGIS] #3785: Setup a Bot to run OSS FUZZ tests
PostGIS trac at osgeo.org
Wed Jul 12 15:57:31 PDT 2017
 Reporter:  robe     |      Owner:  strk
     Type:  task     |     Status:  assigned
 Priority:  medium   |  Milestone:  PostGIS 2.4.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 strk,
 I've created a separate ticket to setup OSS Fuzz testing on our own bots.
 While we are at it, maybe we can figure out Even's issue with having the
 make run from main folder so that we can eventually test more than
 liblwgeom.
 and address kcc's comment here:
 https://github.com/google/oss-fuzz/pull/709
  projects/postgis/build.sh
 +make -j$(nproc) -s
 +cd ..
 +./fuzzers/build_google_oss_fuzzers.sh
 @kcc
 kcc 5 hours ago Contributor
 This should work as is, but it's preferable to have the fuzz targets built
 as part of the regular developer build (make).
 Otherwise the risk is that the fuzz targets will often bit rot and we will
 see failures only on oss-fuzz
 I think you have more mojo to handle this than I do so I'm assigning this
 to you :)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3785>
