[postgis-tickets] [PostGIS] #2995: invalid access to memory location
PostGIS trac at osgeo.org
Wed Jul 26 00:35:12 PDT 2017
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  closed
  Priority:  high     |  Milestone:  PostGIS 2.1.7
 Component:  postgis  |    Version:  2.1.x
Resolution:  fixed    |   Keywords:  windows 64
Comment (by pmeems):
 Not sure if I should open a new ticket but today I run into the same
 issue.
 I have a database running for months now without any problem. I use it on
 a daily basis and yesterday everything was fine.
 Today I get this error when I select a table with a geometry column:
 ERROR: could not load library ''"D:/Program
 Files/PostgreSQL/9.3/lib/postgis-2.1.dll": Invalid access to memory
 location.''
 The same error is shown when I run this command:
 ''SELECT postgis_lib_version()''
 I run Win10 Creator edition 64-Bit.
 Any help is much appreciated since I'm really stuck now.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2995#comment:17>
