[postgis-tickets] [PostGIS] #2995: invalid access to memory location
PostGIS trac at osgeo.org
Wed Jul 26 06:22:54 PDT 2017
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  closed
  Priority:  high     |  Milestone:  PostGIS 2.1.7
 Component:  postgis  |    Version:  2.1.x
Resolution:  fixed    |   Keywords:  windows 64
Comment (by robe):
 well PostgreSQL 9.5 still ships with pgAdmin III. pgAdmin 4 gets replaced
 at 9.6 for windows as I recall.
 Yah no clue what could be different - you didn't install any other new
 software since  else that may be conflicting or window 10 security
 updates.  Those may have upgraded libraries incompatible with the 2.1
 ones.  2.3 I use a newer chain so should be less likely to be an issue
 with newer software.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2995#comment:20>
