[postgis-tickets] [PostGIS] #3720: geobuf regress error on debbie and winnie
PostGIS trac at osgeo.org
Thu Mar 2 22:13:32 PST 2017
  Reporter:  robe     |      Owner:  Björn Harrtell
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  2.3.x
Resolution:           |   Keywords:
Comment (by robe):
 Björn Harrtell,
 If you can't replicate on your end, can you disable the failing test for
 now.  I don't think it's worthwhile reverting ST_AsGeoBuf.
 Unfortunately I'm tied up for a bit, probably next two weeks, so might not
 be able to setup a branch before then for testing.  The only thing I can
 think of that both Debbie and Winnie have in common is they both use
 PostgreSQL compiled with cassert on. I don't think the zlib part is
 important since I think I have on on winnie.
 So I use this command on debbie looks like this to build postgres
 ./configure --prefix=${WORKSPACE}/rel/pg${PG_VER}w${OS_BUILD} --with-
 pgport=${PGPORT} --enable-cassert --enable-debug --without-zlib
 enable-debug and cassert picks up issues you might not normally see with
 memory not being properly cleaned.
 strk - any chance you can try replicating.  You have cassert enabled too
 right.  So you might be seeing the same issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3720#comment:20>
