[postgis-tickets] [PostGIS] #3720: geobuf regress error on debbie and winnie
PostGIS trac at osgeo.org
Sat Mar 4 03:31:34 PST 2017
  Reporter:  robe     |      Owner:  Björn Harrtell
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  2.3.x
Resolution:           |   Keywords:
Comment (by Björn Harrtell):
 Very strange. I get this wierd output on T4 which encodes a POLYGON((0 0,0
 5,5 5,5 0,0 0), (1 1,1 2,2 2,2 1,1 1)). If I remove the inner ring output
 seems ok. If I keep the ring but force the encoding to only consider the
 first ring output is wierd but different than the first case. Almost as if
 the LWGEOM have different semantics if there are multiple rings.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3720#comment:24>
