[postgis-tickets] [PostGIS] #3725: [raster] ST_Clip with multiple band raster throws exception when geometry only touches
PostGIS trac at osgeo.org
Wed Mar 8 12:48:37 PST 2017
only touches
 Reporter:  yosukesabai  |      Owner:  pramsey
     Type:  defect       |     Status:  new
 Priority:  medium       |  Milestone:  PostGIS 2.3.3
Component:  postgis      |    Version:  2.3.x
 Keywords:               |
 I realized that ST_Clip(raster, geometry) gives following error message
 under particular condition:
 ERROR:  RASTER_clip: Could not get band from working raster
 CONTEXT:  PL/pgSQL function st_clip(raster,integer[],geometry,double
 precision[],boolean) line 8 at RETURN
 This happens, I think, when (1) raster has multi-band and (2) raster and
 geometry (polygon) touches with no shared interior.  Below is example sql
 command for demo.
 My version
 version()\\
 PostgreSQL 9.6.1 on x86_64-pc-linux-gnu, compiled by gcc (GCC) 4.9.1,
 64-bit
 postgis_full_version()\\
 POSTGIS="2.3.1 r15264" GEOS="3.6.0-CAPI-1.10.0 r0" PROJ="Rel. 4.9.3, 15
 August 2016" GDAL="GDAL 2.1
 .2, released 2016/10/24" LIBXML="2.9.4" LIBJSON="0.12.1" RASTER
 -- This fails
 SELECT ST_Summary(
         ST_Clip(
                 ST_AddBand(
                         ST_MakeEmptyRaster(16, 16, 0, 0, 1, 1, 0, 0),
                         ARRAY[
                         ROW(1, '8BUI'::text, 0, 255),
                         ROW(2, '8BUI'::text, 0, 255),
                         ROW(3, '8BUI'::text, 0, 255)
                         ]::addbandarg[]
                 ST_GeomFromText('POLYGON((16 0, 16 1, 17 1, 17 0, 16 0))')
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3725>
