[postgis-tickets] r15327 - Add what's new in 2.4 section to docs
Regina Obe lr at pcorp.us
Fri Mar 10 22:06:39 PST 2017
Author: robe
Date: 2017-03-10 22:06:38 -0800 (Fri, 10 Mar 2017)
New Revision: 15327
   trunk/doc/xsl/postgis_aggs_mm.xml.xsl
Modified: trunk/doc/xsl/postgis_aggs_mm.xml.xsl
--- trunk/doc/xsl/postgis_aggs_mm.xml.xsl	2017-03-10 21:54:09 UTC (rev 15326)
+++ trunk/doc/xsl/postgis_aggs_mm.xml.xsl	2017-03-11 06:06:38 UTC (rev 15327)
@@ -481,13 +481,73 @@
 	   <sect1 id="NewFunctions">
 			<title>New, Enhanced or changed PostGIS Functions</title>
-			<note><para>PostGIS 2.3.0: PostgreSQL 9.6+ support for parallel queries.</para></note>
-			<note><para>PostGIS 2.3.0: PostgreSQL 9.4+ support for BRIN indexes. Refer to <xref linkend="brin_indexes" />.</para></note>
-			<note><para>PostGIS 2.3.0: Tiger Geocoder upgraded to work with TIGER 2016 data.</para></note>
+            <sect2 id="NewFunctions_2_4">
+				<title>PostGIS Functions new or enhanced in 2.3</title>
+				<para>The functions given below are PostGIS functions that were added or enhanced.</para>
+				<para>Functions new in PostGIS 2.4</para>
+				<itemizedlist>
+				<!-- Pull out the purpose section for each ref entry and strip whitespace and put in a variable to be tagged unto each function comment  -->
+					<xsl:for-each select='//refentry'>
+						<xsl:sort select="refnamediv/refname"/>
+						<xsl:variable name='comment'>
+							<xsl:value-of select="normalize-space(translate(translate(refnamediv/refpurpose,'&#x0d;&#x0a;', ' '), '	', ' '))"/>
+						</xsl:variable>
+						<xsl:variable name="refid">
+							<xsl:value-of select="@id" />
+						</xsl:variable>
+						<xsl:variable name="refname">
+							<xsl:value-of select="refnamediv/refname" />
+						</xsl:variable>
+				<!-- For each section if there is note about availability in this version -->
+							<xsl:for-each select="refsection">
+								<xsl:for-each select="para | */para">
+									<xsl:choose>
+										<xsl:when test="contains(.,'Availability: 2.4')">
+											<listitem><simpara><link linkend="{$refid}"><xsl:value-of select="$refname" /></link> - <xsl:value-of select="." /><xsl:text> </xsl:text> <xsl:value-of select="$comment" /></simpara></listitem>
+										</xsl:when>
+									</xsl:choose>
+								</xsl:for-each>
+							</xsl:for-each>
+					</xsl:for-each>
+				</itemizedlist>
+				<para>The functions given below are PostGIS functions that are enhanced in PostGIS 2.4.</para>
+				<itemizedlist>
+				<!-- Pull out the purpose section for each ref entry   -->
+						<xsl:sort select="@id"/>
+						</xsl:variable>
+						</xsl:variable>
+				<!-- For each section if there is note about enhanced in this version -->
+									<xsl:choose>
+										<xsl:when test="contains(.,'Enhanced: 2.4')">
+											<listitem><simpara><link linkend="{$refid}"><xsl:value-of select="$refname" /></link> - <xsl:value-of select="." /></simpara></listitem>
+										</xsl:when>
+									</xsl:choose>
+								</xsl:for-each>
+							</xsl:for-each>
+					</xsl:for-each>
+				</itemizedlist>
+			</sect2>
 			<sect2 id="NewFunctions_2_3">
+                <note><para>PostGIS 2.3.0: PostgreSQL 9.6+ support for parallel queries.</para></note>
+                <note><para>PostGIS 2.3.0: PostGIS extension, all functions schema qualified to reduce issues in database restore.</para></note>
+                <note><para>PostGIS 2.3.0: PostgreSQL 9.4+ support for BRIN indexes. Refer to <xref linkend="brin_indexes" />.</para></note>
+                <note><para>PostGIS 2.3.0: Tiger Geocoder upgraded to work with TIGER 2016 data.</para></note>
 				<para>Functions new in PostGIS 2.3</para>
 				<itemizedlist>
