[postgis-tickets] r15330 - Fix azimuth computation for 2.5D edge ends
Sandro Santilli strk at kbt.io
Sat Mar 11 08:21:18 PST 2017
Author: strk
Date: 2017-03-11 08:21:18 -0800 (Sat, 11 Mar 2017)
New Revision: 15330
   trunk/liblwgeom/lwgeom_topo.c
   trunk/topology/test/regress/topogeo_addlinestring.sql
   trunk/topology/test/regress/topogeo_addlinestring_expected_newsnap
   trunk/topology/test/regress/topogeo_addlinestring_expected_oldsnap
The change disreguard vertical movemements of the edge and computes
azimuth of the first segment getting away from the node.
Includes automated testcase
See #3711
Modified: trunk/liblwgeom/lwgeom_topo.c
--- trunk/liblwgeom/lwgeom_topo.c	2017-03-11 14:33:33 UTC (rev 15329)
+++ trunk/liblwgeom/lwgeom_topo.c	2017-03-11 16:21:18 UTC (rev 15330)
@@ -1401,7 +1401,7 @@
  * Get first distinct vertex from endpoint
  * @param pa the pointarray to seek points in
  * @param ref the point we want to search a distinct one
- * @param from vertex index to start from
+ * @param from vertex index to start from (will really start from "from"+dir)
  * @param dir  1 to go forward
  *            -1 to go backward
  * @return 0 if edge is collapsed (no distinct points)
@@ -1570,7 +1570,12 @@
     if ( edge->start_node == node ) {
       getPoint2d_p(pa, 0, &p1);
-      getPoint2d_p(pa, 1, &p2);
+      if ( ! _lwt_FirstDistinctVertex2D(pa, &p1, 0, 1, &p2) )
+        lwerror("Edge %d has no distinct vertices: [%.15g %.15g,%.15g %.15g]: ",
+                edge->edge_id, p1.x, p1.y, p2.x, p2.y);
+        return -1;
       LWDEBUGF(1, "edge %" LWTFMT_ELEMID
                   " starts on node %" LWTFMT_ELEMID
                   ", edgeend is %g,%g-%g,%g",
@@ -1627,7 +1632,12 @@
     if ( edge->end_node == node ) {
       getPoint2d_p(pa, pa->npoints-1, &p1);
-      getPoint2d_p(pa, pa->npoints-2, &p2);
+      if ( ! _lwt_FirstDistinctVertex2D(pa, &p1, pa->npoints-1, -1, &p2) )
+        return -1;
       LWDEBUGF(1, "edge %" LWTFMT_ELEMID " ends on node %" LWTFMT_ELEMID
                   edge->edge_id, node, p1.x, p1.y, p2.x, p2.y);
@@ -2362,6 +2372,7 @@
   newedge.geom = geom;
   newedge.face_left = -1;
   newedge.face_right = -1;
+  /* TODO: should do the repeated points removal in 2D space */
   cleangeom = lwgeom_remove_repeated_points( lwline_as_lwgeom(geom), 0 );
   pa = lwgeom_as_lwline(cleangeom)->points;
@@ -2375,18 +2386,17 @@
   span.cwFace = span.ccwFace =
   epan.cwFace = epan.ccwFace = -1;
-  /* Compute azimut of first edge end on start node */
+  /* Compute azimuth of first edge end on start node */
-  getPoint2d_p(pa, 1, &pn);
-  if ( p2d_same(&p1, &pn) ) {
+  if ( ! _lwt_FirstDistinctVertex2D(pa, &p1, 0, 1, &pn) )
     lwgeom_free(cleangeom);
-    /* Can still happen, for 2-point lines */
     lwerror("Invalid edge (no two distinct vertices exist)");
     return -1;
   if ( ! azimuth_pt_pt(&p1, &pn, &span.myaz) ) {
-    lwerror("error computing azimuth of first edgeend [%g,%g-%g,%g]",
+    lwerror("error computing azimuth of first edgeend [%.15g %.15g,%.15g %.15g]",
             p1.x, p1.y, pn.x, pn.y);
     return -1;
@@ -2394,10 +2404,16 @@
   /* Compute azimuth of last edge end on end node */
   getPoint2d_p(pa, pa->npoints-1, &p2);
-  getPoint2d_p(pa, pa->npoints-2, &pn);
+  if ( ! _lwt_FirstDistinctVertex2D(pa, &p2, pa->npoints-1, -1, &pn) )
+    lwgeom_free(cleangeom);
+    /* This should never happen as we checked the edge while computing first edgend */
+    lwerror("Invalid clean edge (no two distinct vertices exist) - should not happen");
+    return -1;
   if ( ! azimuth_pt_pt(&p2, &pn, &epan.myaz) ) {
-    lwerror("error computing azimuth of last edgeend [%g,%g-%g,%g]",
+    lwerror("error computing azimuth of last edgeend [%.15g %.15g,%.15g %.15g]",
             p2.x, p2.y, pn.x, pn.y);
     return -1;
Modified: trunk/topology/test/regress/topogeo_addlinestring.sql
--- trunk/topology/test/regress/topogeo_addlinestring.sql	2017-03-11 14:33:33 UTC (rev 15329)
+++ trunk/topology/test/regress/topogeo_addlinestring.sql	2017-03-11 16:21:18 UTC (rev 15330)
@@ -322,3 +322,13 @@
 '0102000000020000003AB42BBFEE4C22410010C5A997A6524167BB5DBDEE4C224117FE3DA85FA75241'
 ::geometry, 0);
 SELECT 't3412.end', DropTopology('bug3412');
+-- See http://trac.osgeo.org/postgis/ticket/3711
+SELECT 't3371.start', topology.CreateTopology('bug3711', 0, 0, true) > 1;
+SELECT 't3371.L1', topology.TopoGeo_AddLineString('bug3711',
+'LINESTRING (618369 4833784 0.88, 618370 4833784 1.93, 618370 4833780 1.90)'
+::geometry, 0);
+SELECT 't3371.L2', topology.TopoGeo_AddLineString( 'bug3711',
+'LINESTRING (618370 4833780 1.92, 618370 4833784 1.90, 618371 4833780 1.93)'
+::geometry, 0);
+SELECT 't3371.end', topology.DropTopology('bug3711');
Modified: trunk/topology/test/regress/topogeo_addlinestring_expected_newsnap
--- trunk/topology/test/regress/topogeo_addlinestring_expected_newsnap	2017-03-11 14:33:33 UTC (rev 15329)
+++ trunk/topology/test/regress/topogeo_addlinestring_expected_newsnap	2017-03-11 16:21:18 UTC (rev 15330)
@@ -201,3 +201,8 @@
 t3412.L2|5
 t3412.L2|4
 t3412.end|Topology 'bug3412' dropped
+t3371.start|t
+t3371.L1|1
+t3371.L2|3
+t3371.L2|2
+t3371.end|Topology 'bug3711' dropped
Modified: trunk/topology/test/regress/topogeo_addlinestring_expected_oldsnap
--- trunk/topology/test/regress/topogeo_addlinestring_expected_oldsnap	2017-03-11 14:33:33 UTC (rev 15329)
+++ trunk/topology/test/regress/topogeo_addlinestring_expected_oldsnap	2017-03-11 16:21:18 UTC (rev 15330)
@@ -198,3 +198,8 @@
 t3412.L2|5
 t3412.L2|4
+t3371.start|t
+t3371.L1|1
+t3371.L2|3
+t3371.L2|2
