[postgis-tickets] r15339 - Clean up C style
bjorn at wololo.org bjorn at wololo.org
Sat Mar 18 04:59:23 PDT 2017
Author: bjornharrtell
Date: 2017-03-18 04:59:23 -0700 (Sat, 18 Mar 2017)
New Revision: 15339
   trunk/postgis/geobuf.c
   trunk/postgis/mvt.c
   trunk/postgis/mvt.h
Clean up C style
Modified: trunk/postgis/geobuf.c
--- trunk/postgis/geobuf.c	2017-03-18 11:59:04 UTC (rev 15338)
+++ trunk/postgis/geobuf.c	2017-03-18 11:59:23 UTC (rev 15339)
@@ -30,7 +30,8 @@
 #define FEATURES_CAPACITY_INITIAL 50
 #define MAX_PRECISION 1e6
-static Data__Geometry *encode_geometry(struct geobuf_agg_context *ctx, LWGEOM *lwgeom);
+static Data__Geometry *encode_geometry(struct geobuf_agg_context *ctx,
+	LWGEOM *lwgeom);
 static Data__Geometry *galloc(Data__Geometry__Type type) {
 	Data__Geometry *geometry;
@@ -82,7 +83,9 @@
-static void encode_properties(struct geobuf_agg_context *ctx, Data__Feature *feature) {
+static void encode_properties(struct geobuf_agg_context *ctx,
+	Data__Feature *feature)
 	uint32_t *properties;
 	Data__Value **values;
 	uint32_t i, k = 0, c = 0;
@@ -144,7 +147,9 @@
 	feature->properties = properties;
-static int64_t *encode_coords(struct geobuf_agg_context *ctx, POINTARRAY *pa, int64_t *coords, int len, int offset) {
+static int64_t *encode_coords(struct geobuf_agg_context *ctx, POINTARRAY *pa,
+	int64_t *coords, int len, int offset)
 	int i, c;
 	POINT4D pt;
 	int64_t sum[] = { 0, 0, 0, 0 };
@@ -152,7 +157,8 @@
 	if (offset == 0)
 		coords = palloc(sizeof (int64_t) * len * ctx->dimensions);
 	else
-		coords = repalloc(coords, sizeof (int64_t) * ((len * ctx->dimensions) + offset));
+		coords = repalloc(coords, sizeof (int64_t) *
+			((len * ctx->dimensions) + offset));
 	c = offset;
 	for (i = 0; i < len; i++) {
@@ -167,7 +173,9 @@
 	return coords;
-static Data__Geometry *encode_point(struct geobuf_agg_context *ctx, LWPOINT *lwpoint) {
+static Data__Geometry *encode_point(struct geobuf_agg_context *ctx,
+	LWPOINT *lwpoint)
 	int npoints;
 	POINTARRAY *pa;
@@ -186,7 +194,9 @@
 	return geometry;
-static Data__Geometry *encode_mpoint(struct geobuf_agg_context *ctx, LWMPOINT *lwmpoint) {
+static Data__Geometry *encode_mpoint(struct geobuf_agg_context *ctx,
+	LWMPOINT *lwmpoint)
 	int i, ngeoms;
 	POINTARRAY *pa;
@@ -212,7 +222,9 @@
 	return geometry;
-static Data__Geometry *encode_line(struct geobuf_agg_context *ctx, LWLINE *lwline) {
+static Data__Geometry *encode_line(struct geobuf_agg_context *ctx,
+	LWLINE *lwline)
 	POINTARRAY *pa;
@@ -229,7 +241,9 @@
 	return geometry;
-static Data__Geometry *encode_mline(struct geobuf_agg_context *ctx, LWMLINE *lwmline) {
+static Data__Geometry *encode_mline(struct geobuf_agg_context *ctx,
+	LWMLINE *lwmline)
 	int i, offset, ngeoms;
 	POINTARRAY *pa;
@@ -264,7 +278,9 @@
 	return geometry;
-static Data__Geometry *encode_poly(struct geobuf_agg_context *ctx, LWPOLY *lwpoly) {
+static Data__Geometry *encode_poly(struct geobuf_agg_context *ctx,
+	LWPOLY *lwpoly)
 	int i, len, nrings, offset;
 	POINTARRAY *pa;
@@ -300,7 +316,9 @@
 	return geometry;
-static Data__Geometry *encode_mpoly(struct geobuf_agg_context *ctx, LWMPOLY* lwmpoly) {
+static Data__Geometry *encode_mpoly(struct geobuf_agg_context *ctx,
+	LWMPOLY* lwmpoly)
 	int i, j, c, len, offset, n_lengths, ngeoms, nrings;
 	POINTARRAY *pa;
@@ -349,7 +367,9 @@
 	return geometry;
-static Data__Geometry *encode_collection(struct geobuf_agg_context *ctx, LWCOLLECTION* lwcollection) {
+static Data__Geometry *encode_collection(struct geobuf_agg_context *ctx,
+	LWCOLLECTION* lwcollection)
 	int i, ngeoms;
 	Data__Geometry *geometry, **geometries;
@@ -373,7 +393,9 @@
 	return geometry;
-static Data__Geometry *encode_geometry(struct geobuf_agg_context *ctx, LWGEOM *lwgeom) {
+	LWGEOM *lwgeom)
 	int type = lwgeom->type;
 	switch (type)
@@ -398,12 +420,14 @@
 	return NULL;
-static void analyze_val(struct geobuf_agg_context *ctx, double val) {
+static void analyze_val(struct geobuf_agg_context *ctx, double val)
 	if (ceil(val * ctx->e) / ctx->e != val && ctx->e < MAX_PRECISION)
 		ctx->e *= 10;
-static void analyze_pa(struct geobuf_agg_context *ctx, POINTARRAY *pa) {
+static void analyze_pa(struct geobuf_agg_context *ctx, POINTARRAY *pa)
 	int i;
 	POINT4D pt;
 	for (i = 0; i < pa->npoints; i++) {
@@ -417,7 +441,8 @@
-static void analyze_geometry(struct geobuf_agg_context *ctx, LWGEOM *lwgeom) {
+static void analyze_geometry(struct geobuf_agg_context *ctx, LWGEOM *lwgeom)
 	int i, type;
 	LWLINE *lwline;
 	LWPOLY *lwpoly;
@@ -449,7 +474,9 @@
-static void analyze_geometry_flags(struct geobuf_agg_context *ctx, LWGEOM *lwgeom) {
+static void analyze_geometry_flags(struct geobuf_agg_context *ctx,
+	LWGEOM *lwgeom)
 	if (!ctx->has_dimensions) {
 		if (FLAGS_GET_Z(lwgeom->flags) || FLAGS_GET_M(lwgeom->flags))
 			ctx->dimensions = 3;
@@ -461,10 +488,8 @@
-static Data__Feature *encode_feature(struct geobuf_agg_context *ctx) {
+static Data__Feature *encode_feature(struct geobuf_agg_context *ctx)
 	Data__Feature *feature;
 	feature = palloc (sizeof (Data__Feature));
@@ -573,20 +598,19 @@
 		data->has_dimensions = ctx->has_dimensions;
 		data->dimensions = ctx->dimensions;
-	lwdebug(3, "data->dimensions: %d", data->dimensions);
 	/* check and set precision if not default */
 	if (ctx->e > MAX_PRECISION)
 		ctx->e = MAX_PRECISION;
 	ctx->precision = ceil(log(ctx->e) / log(10));
-	lwdebug(3, "ctx->precision: %d", ctx->precision);
 	if (ctx->precision != 6) {
 		data->has_precision = 1;
 		data->precision = ctx->precision;
 	for (i = 0; i < fc->n_features; i++)
-		fc->features[i]->geometry = encode_geometry(ctx, ctx->lwgeoms[i]);
+		fc->features[i]->geometry = encode_geometry(ctx,
+			ctx->lwgeoms[i]);
 	size_t len = data__get_packed_size(data);
 	uint8_t *buf = palloc(sizeof(*buf) * (len + VARHDRSZ));
Modified: trunk/postgis/mvt.c
--- trunk/postgis/mvt.c	2017-03-18 11:59:04 UTC (rev 15338)
+++ trunk/postgis/mvt.c	2017-03-18 11:59:23 UTC (rev 15339)
@@ -282,7 +282,7 @@
 		keys[k++] = key;
 	if (!geom_name_found)
-		lwerror("encode_keys: no column with specificed geom_name found");
+		lwerror("encode_keys: no column '%s' found", ctx->geom_name);
 	ctx->layer->n_keys = k;
 	ctx->layer->keys = keys;
 	ReleaseTupleDesc(tupdesc);
@@ -365,7 +365,7 @@
 static void parse_value_as_string(struct mvt_agg_context *ctx, Oid typoid,
-		Datum datum, uint32_t *tags, uint32_t c, uint32_t k)
+	Datum datum, uint32_t *tags, uint32_t c, uint32_t k)
 	struct mvt_kv_string_value *kv;
 	Oid foutoid;
@@ -464,7 +464,7 @@
  * dimension.
 LWGEOM *mvt_geom(LWGEOM *lwgeom, GBOX *gbox, uint32_t extent, uint32_t buffer,
-		 bool clip_geom)
+	bool clip_geom)
 	double width = gbox->xmax - gbox->xmin;
 	double height = gbox->ymax - gbox->ymin;
Modified: trunk/postgis/mvt.h
--- trunk/postgis/mvt.h	2017-03-18 11:59:04 UTC (rev 15338)
+++ trunk/postgis/mvt.h	2017-03-18 11:59:23 UTC (rev 15339)
@@ -64,7 +64,8 @@
 	uint32_t values_hash_i;
-LWGEOM *mvt_geom(LWGEOM *geom, GBOX *bounds, uint32_t extent, uint32_t buffer, bool clip_geom);
+LWGEOM *mvt_geom(LWGEOM *geom, GBOX *bounds, uint32_t extent, uint32_t buffer,
+	bool clip_geom);
 void mvt_agg_init_context(struct mvt_agg_context *ctx);
 void mvt_agg_transfn(struct mvt_agg_context *ctx);
 uint8_t *mvt_agg_finalfn(struct mvt_agg_context *ctx);
