[postgis-tickets] [PostGIS] #3731: SELECT * FROM testgeom WHERE ST_Intersects() and the back-end crashes
PostGIS trac at osgeo.org
Sun Mar 26 16:22:18 PDT 2017
  Reporter:  zhuodao     |      Owner:  pramsey
      Type:  defect      |     Status:  new
  Priority:  medium      |  Milestone:  PostGIS 2.1.9
 Component:  postgis     |    Version:  2.2.x
Resolution:              |   Keywords:  ST_Intersects estimate_selectivity
                         |  not a number
Comment (by pramsey):
 * If you use 2.2.5 does the issue persist? http://postgis.net/source/
 * Can you share the contents if your table? pg_dump -t testgeom
 Thanks
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3731#comment:1>
