[postgis-tickets] [PostGIS] #3739: ST_Within Not using index
PostGIS trac at osgeo.org
Mon May 1 01:04:03 PDT 2017
  Reporter:  postgispaul  |      Owner:  pramsey
      Type:  defect       |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS 2.3.3
 Component:  postgis      |    Version:  2.3.x
Resolution:               |   Keywords:
Comment (by robe):
 ahah so I think I was wrong, it is aware of the option to use the index,
 but has wrongly concluded it is worse to do so than to use it because it
 estimated a traversal count of 265635 rows when there is only 103258 rows.
 Why extra ~ puts it over the edge is a bit of a mystery.  I suspect it's
 just treating it as an extra condition and so multiplying the rows it has
 to traverse for the cost, which sways it back in the other direction. So
 it's just dumb luck.
 One more test,
 Can you move the ~ inside the ST_Within
 so ~ and ~.  I'm suspecting it will have the same affect as it being
 outside, but just want to confirm that.
 Aside from Paul's (pramsey) note about improving ~ selectivity, perhaps
 managing this ourselves, I'm not sure there is much we can do about this.
 Even with that, I'm not sure how that would help, as it seems to be very
 data specific.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3739#comment:26>
